1. A new Roof
Fitted2. New Hi Spec Rear Callipers (useable and not leaking)
Fitted, also went for the bigger disc's all round, very happy with a handbrake that passed the MOT3. Suspension,
Still sitting on the fence4. Upgrade gear change cables Joined the group buy for Bob's super slick cable's
Fitted and very happy5. Samco hoses
Fitted 6. New Ali Rad
Fitted7. Nardi Steering wheel, anybody got one ?
fitted a Momo instead8. Rear wish bones ,
Got some galvanised on the to do list9. Sort the waste gate finally started to remove the Turbo what fun
10. Pair of S2000 seats in black
Changed my mind on this will probably go for a recover11.New Plastic Heater Valve
12.New Metal rear number plate (the plastic ones warp under the plastic cover)
Fitted13.Get a Shower cap Bought a cheap one under a tenner ! will post if any good
14. Piper Down pipe and possible exhaust system depending on results from testing
the more I'm removing the old down pipe the more I'm thinking it's a good ideaOk so I've started to remove the Turbo to port the waste gate
, this was brought forward because my down pipe decided to part company with the catalyst housing, it sheared leaving the flange still bolted to the housing
So drawing on the experiences on here (some bad)I proceeded to remove the Turbo.
So far it's all gone quite smoothly, no sheared studs or bolts (so far).
I'm now at the point where the large catalyst housing is loose and sliding nicely along the studs, there are three remaining studs as the shortest one decided to unscrew with the nut.
I've released the power steering pump but there's not quiet enough room to slide the housing off the remaining studs,
so I'm now wondering do I need to remove the studs (which need to be replaced) first and or the coolant outlet pipe from the block that seems to be in the way too.
I'm also going to sort out the oil cooler pipes while the cars off the road
