Cam belt replacement parts
Re: Cam belt replacement parts
Postby Stef » Sun 30.12.2012, 22:44
As Brit-Car-Nut's compilation is cheapest and now seems to include all that is needed that is the lot to get! Although in the rock auto listsing I'm looking at under Timing Belt Kit, there is no listing for the Water Pump, so what section does that fall under?! (Still not easy is it??! :lol: )
The kit Intkin suggests does not mention the belts so seemed confusing to me.
Should I need to replace the water pump? (just seen aaditional posting...)
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Brit-Car-Nut » Sun 30.12.2012, 22:57
Still very easy. The timing belts are considered part of the engine "system" and the water pump is considered part of the cooling "system".
The other drive belts are considered to be part of the Belt Drive "system". You look up parts by their system.
The kit Intkin suggests does not include anything but the cam belt, idler, tensioner and water pump. The drive belts are in addition to the cam parts.
Belt Alternator GATES Part # K040270
Belt PAS no A/C GATES Part # K060380
I haven't looked these up but Baldydash said they are for the non-A/C car, so not correct for a car with A/C. Stef: does your new car have Air Conditioning?
Postby inkitin » Sun 30.12.2012, 23:00
Stef
The only part that it is necessary to replace is the timing belt. I'm assuming that is your main intention.
Gaining access to replace the timing belt is time consuming (read expensive if you're paying someone to do it for you!).
The other three parts that are optional to replace at the same time are the idler wheel, tensioner wheel and the water pump. You don't have to replace these parts but if you don't and one of them gives way at a later date, it's very time consuming (read expensive again) to go back in and replace any of them.
So the general advice (i.e. most people do this) is to replace/renew the other three parts at the same time. That's why there's a Dayco kit that contains all the parts you need. Brit-car-nut is correct in that you can save a few quid by following his recommendations for buying separately. To be honest, I couldn't be bothered at the time so for ease I ordered the "all in one" kit (yes, I'm an eccentric millionaire ! :lol: ).
The other thing not to forget is that HM Government will require some money off you when the parts hit the shores of the UK. Some have got away with it, I never have. :twisted:
91 SE Calypso Red
inkitin
Postby Stef » Sun 30.12.2012, 23:10
Righty... So might just as well do the lot also then!
Yes, main reason was that cambelt is due but it seems doing the lot is advisable with little additional cost.
Will be getting done at a garage so the 'expensive' part is understood!
Dayco kit and Gates water pump is what I shall be ordering. x 2. Tomorrow! Because thinks I've had enough of this for tonight! :lol:
Thanks so much for everyone's input. Hopefully has made options a little more understandable for others too.
Fingies crossed there will be no meddling by the Gov's gready paws...
Stef
Postby epipete » Sun 30.12.2012, 23:52
Thanks Guys (and Gals), I also understand the requirement now.
Postby Fredjohn » Mon 31.12.2012, 00:08
Guys
Am also interested in changing cam belt idler and tensioner as well as water pump at same time. As Inkitin says it is easier to order Dayco WP169K1A at £64.96 which includes all 4 items. Postage for this one package to UK is £47. ie £112 total.
If you order 2, total postage goes up to £56, if you order 3 it goes up to £65, at 4 up to £78. ie now below £20 per person.
If you order the cheaper cambelt kit at £23.38 plus seperate water pump at £18.49, the combined postage is £76. ie £117 total. So it is £5 cheaper to do the above and you get a water pump for free.
If you then add the alternator belt and the PAS belt at about £5 each the postage for each of these 2 items is c£23. You are better off buying these belts from a local supplier or from SJ Sports.
Just go on website and add to basket to confirm these shipping costs!!!!
So I am happy to join in with 2/3/4 others to buy WP169K1A to minimise shipping costs.
All prices exclude any discount code and we will also be liable for UK import/VAT charges.
Any takers???
Postby Brit-Car-Nut » Mon 31.12.2012, 02:00
OK, so Rock Auto would treat the two items as separate orders but you could choose the GATES Part # 41053 water pump for 18.49 and GOODYEAR Part # GTK0169 Timing Belt Kit for 30.25 and they would ship together for 38.06. It appears that Dayco is not a direct warehouse for Rock Auto. That is why the shipping is higher too. Bad news is Rock Auto is saying they only have one belt kit available.
I used the post code for my storage in Notts.
I am really surprised that there is no warehouse access in the UK for these parts so you don't have to pay the outrageous shipping costs. How Lotus can try to sell the water pump for 120.00 is beyond my understanding.
Postby Stef » Mon 31.12.2012, 10:22
Wo... :shock: How an overnight pause can flare it all up again! :lol:
So, postage varies eh?!
Guess we have a couple of options here, there isso far now 3 of us looking to order. We can either wait for more Goodyear belts and then order OR go for the Dayco WP169K1A kit now.
Persoonally I'm in no mega rush, couple months will be ok, and as long as we have a valid discount code (which we don't know how much will save us yet but more the merrier!).
Presuming between all us LECers there will always be a valid code bouncing about waiting shouldn't be an issue??
Stef
Postby inkitin » Mon 31.12.2012, 11:57
Stef wrote:Presuming between all us LECers there will always be a valid code bouncing about waiting shouldn't be an issue??
They're always out there somewhere! :-)
A 30 second Google search and hey presto:
"5% Discount Code: 710F1AC6FB23
Expires: 03/24/2013 (24th March 2013 for us Brits :roll: )
Please enter this code in the ‘How Did You Hear about Us’ box to receive discount. Please note that orders using discount codes must be placed online and the discount code must be entered before an order is submitted to receive the discount. Phone orders are not eligible for discounts.
RockAuto.com is an online auto parts store founded in Madison, Wisconsin in 1999 by the Taylor family. RockAuto.com now ships thousands of auto parts from over 200 manufacturers to customers worldwide.
The RockAuto Auto Parts catalog is updated daily with mechanical parts like brake pads and shock absorbers, body parts like bumpers and mirrors, interior trim like door handles and carpets, and major assemblies like steering gears, CV axles, and engine long blocks. Service manuals and CDs are available to help customers learn how to perform a repair. The RockAuto Auto Parts catalog is expanding constantly. Someday it may be possible to build an entire car using parts from RockAuto.com!
RockAuto.com prices are low every day! Order online at RockAuto Auto Parts 24 hours a day. Parts are conveniently delivered to your door. Have parts questions that must be answered accurately? RockAuto.com has excellent customer service agents ready to help you get the parts you need. E-mail service@rockauto.com or call Toll Free, 1-866-762-5288. (Mon - Thur 6 to 10 / Fri 6 to 9 / Sat 7 to 6 / Sun 8 to 4 Central Standard Time)."
91 SE Calypso Red
inkitin
Postby Stef » Fri 04.01.2013, 09:04
To confirm, Parts including waterpump for me, Baldydash and Fredjohn. Any others?
Shall I wait for the cheaper Godyear compilation or ordr now with the Dayco kit?
Please advise!
Parts can be posted on or collected at a meet! :-)
Stef
Postby woody » Fri 04.01.2013, 12:02
Stef,
Count me in for a full set please
Woody
woody
Postby Fredjohn » Fri 04.01.2013, 12:39
Stef wrote:To confirm, Parts including waterpump for me, Baldydash and Fredjohn. Any others?
Please advise!
Stef
As the Gates water pump comes from 2 different locations if you order more than one, it bumps up the shipping costs again. So also as Goodyear compilation currently not available it would seem to me to make sense to order 4 off single unit Dayco part WP169K1A now which works out at £340 total (£85 each) plus UK import/VAT for 4 people.
Rockauto check out page also shows a calculation for 5% discount and VAT: total price of £391 (£98 each) which is the amount payable to them.
There would appear to be 4 people now:
Stef
Woody
Baldyash
What of the originator of this thread (Colinr) which we seem to have hi-jacked!!! RU interested Colinr?? For 5 the price each would be £106 (vs £98 for 4!!) as the 5th one adds £53 to shipping costs. Must be weight/volume impact :shock:
I am happy to proceed on this basis. (preferably 4 but ok with 5)
Postby baldyash » Fri 04.01.2013, 13:15
I can confirm that I'm OK to order
Stef / others --regarding payment how would you like to proceed?
baldyash
Postby Fredjohn » Fri 04.01.2013, 13:45
baldyash wrote:As we are replacing the water pump wont we need a gasket----BECK/ARNLEY Part # 0394100 @ 68p (!) under cooling in the engine menu. It doesn't appear to be in the "kit"
I can confirm that I'm OK to order everything Kit( +gasket ?)
Gasket would add £5 per person to overall bill (on top of £98). SJ do it for £2.79 plus vat plus postage, so just a tad cheaper from US I guess.
I'm OK with this.
Stef similar question re payment........
EDIT: Rockauto description of Dayco kit says gasket included (with instructions!!) so no need to order it seperately. John
Postby baldyash » Fri 04.01.2013, 14:07
Fredjohn---Sorry made an error I edited my post as it appears gaskets are included (didn't read info picture correctly) But I think you must have beaten me to it!!!!
baldyash
Postby Fredjohn » Fri 04.01.2013, 14:21
Baldyash
It took me 3 looks to spot the text :bonk:
Postby Stef » Fri 04.01.2013, 17:00
OK
Ordering 4 Dayco kits now! :D
Stef
Postby Stef » Fri 04.01.2013, 17:09
£403.89 was the total.
Paypay payment.
Happy to accept cheques to avoid Paypal fees myself!
Lets hope all goes smoothly! :-D
Stef
Postby Fredjohn » Fri 04.01.2013, 17:21
Stef wrote:£403.89 was the total.
Paypay payment.
Great thanks Stef. I assume you applied the discount code!!!!!!!!!!!!!!!! as I could only get it to £390.83.
So I/we owe you £100.9725/each.
Please PM your full name/address to send cheque or if you are happy bank details and I can do an immediate on line bank transfer. Can then collect once arrived.
Again many thanks :-D :burnout:
Postby baldyash » Fri 04.01.2013, 18:02
Stef can you PM me as well with detailsl--Thanks for doing this
baldyash
