cv joint
cv joint
Postby sprogg7 » Fri 07.06.2013, 14:37
hi everyone
while trying to replace the front wheel bearing i damaged the end of the drive shaft...i know..
are the cv joints common to any other car or are they just lotus
cheers
sprogg
1990 lotus elan m100
1998 mgf vvc
sprogg7
Re: cv joint
Postby Brit-Car-Nut » Fri 07.06.2013, 16:09
For a shop that specializes in CV repair, they are common: One is common to a Ford and the other is common to a Subaru. Getting both of the CV joints in the axle rebuilt in the US runs around $80.00
Re: cv joint
Postby hatters » Fri 07.06.2013, 19:46
Can you not run a die down the stub axle and clean up the threads ?
hatters
Re: cv joint
Postby Brit-Car-Nut » Fri 07.06.2013, 19:51
I assumed that he broke the actual joint while trying to pull the hub bearing off the shaft. The spline end is unique to the M100, the CV joint is not special.
Re: cv joint
Postby tweetdriver63 » Fri 07.06.2013, 20:04
Am I missing something? I thought the CV joints were also common to the Impulse. If so, can be gotten for about $70 online, and stores like Advance Auto Parts have them too.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Re: cv joint
Postby sprogg7 » Fri 07.06.2013, 20:21
hi guys
the nut holding the wheel bearing was seized so it had to be cut off...
this then damaged the spline, the c/v joint its self is fine by the spline is too damaged just to cut the threads.
thanks for your help so far
1998 mgf vvc
sprogg7
Re: cv joint
Postby Brit-Car-Nut » Fri 07.06.2013, 20:29
The axles are not the same as an Impulse.
