by epipete » Fri 10.01.2014, 19:49
Oh, pleeeeze; will the fun never end?
Today I have attached the coolant supply to the Turbo; or to be more precise I have attempted to attach the coolant supply to the Turbo!
Having obtained the necessary washers and cleaned the old banjo's I tried to install the first banjo into the lower of the two 'holes' with a washer on either side of the pipe joint, as per the advice above, and, indeed, in the manual, ('though when I removed these banjo's there was only one washer on each this being at the banjo head end!)
Well, with two washers I couldn't get any thread to grip so I removed the washer between the connector and the turbo, again, I was unable to get any grip. I then swapped the banjo bolts and this time I was able to tighten the bottom pipe up satisfactorily.
I now tried to connect the upper pipe; this time I was unable to get any bite on the tread with either two or, indeed, just one washer! Without washers or connector I can get the banjo to screw into the hole but it needs to penetrate to a death greater than the widths of the connector before it will bite. Given that this is the same banjo that wouldn't bite on the lower connection it would suggest that it is the banjo that is the problem. But I fear that the 'early'/ outer threads on the turbo may be worn!
The depth of the banjo is, as per the photo, 25mm and I shall try to replace with the same, however does anyone know if a banjo of, say 28mm exists or indeed if there is sufficient depth to allow a longer bolt?
Ideas, theory's, spare shoulders and psychiatrist addresses would be appreciated!
Pete
