Heat Shield
Heat Shield
Postby nicowalker1 » Tue 20.05.2014, 21:30
Im looking to paint the top heat shield as even after quite a good scrub with a steel wheel the surface is pitted.
Would this withstand the temperature?
http://www.halfords.com/webapp/wcs/stor ... yId_165495
there is a very high temp version but that is only available in matt
nicowalker1
Re: Heat Shield
Postby dapinky » Tue 20.05.2014, 21:58
Nick,
I used the Halford own brand VHT spray in the Aluminium colour - not sure how long it will last, but it's been 7 years so far :D
Re: Heat Shield
Postby nicowalker1 » Thu 22.05.2014, 20:26
Cheers! Im thinking gloss back with red on the turbo writing, im going to go black on the rocker cover with a red and black plate.
If it looks naff i can always strip it...
nicowalker1
Re: Heat Shield
Postby Rice crispy » Thu 22.05.2014, 20:41
I used matt black vht paint on mine and its been fine for 2 years
Rice crispy
Re: Heat Shield
Postby Rambo » Thu 22.05.2014, 23:28
nicowalker1 wrote:Cheers! Im thinking gloss back with red on the turbo writing, im going to go black on the rocker cover with a red and black plate.
I think you'll be stripping it Nick :lol: :lol:
Re: Heat Shield
Postby Enright » Fri 23.05.2014, 08:03
Hmm, not sure how well that would work. I like the idea of the gloss black cam cover (and maybe just polish the LOTUS lettering on it), but think that that a plain silver turbo heat-shield and matching spark plug cover would be better.
The detailing might look a bit fiddly - to retain a theme it could be best to go with black on silver, as per the plenum.
Re: Heat Shield
Postby trig » Fri 23.05.2014, 18:37
Here's one I did earlier :-D , Halfords High Temp paint , Still looks great years later
trig
Re: Heat Shield
Postby nicowalker1 » Fri 23.05.2014, 21:21
Cheers for the pics I'm definitely going to give it a try
nicowalker1
Re: Heat Shield
Postby DABgp » Sat 24.05.2014, 06:46
trig wrote:Here's one I did earlier :-D , Halfords High Temp paint , Still looks great years later
LIke it. One of the most subtle under bonnet scenes on an Elan I've seen. No naff blue hoses.:wink: But why not give Isuzu some credit?
DABgp
Re: Heat Shield
Postby nicowalker1 » Sat 24.05.2014, 07:39
Did you use laquer on the cam cover?
nicowalker1
Re: Heat Shield
Postby Enright » Sat 24.05.2014, 10:18
I really like that - very nice theme. 8)
My only query, and I'm really nit-picking here, is why leave the "-" before the LOTUS if you're going to the trouble of getting rid of the ISUZU and the lugs? :?
Re: Heat Shield
Postby trig » Mon 26.05.2014, 08:45
Go for it Nick, it's a very easy mod with no special tools or skills needed and yes I used laquer on cam cover but not heat shield as I did not think it would handle the heat
DABgp, Isuzu do deserve credit for a cracking little engine, I just don't think the word Isuzu is as sexy as Lotus :-D
Neil, leaving the - before the Lotus was a mistake :oops: , don't know what I was thinking :roll:
trig
Re: Heat Shield
Postby GeoffSmith » Mon 26.05.2014, 12:20
trig wrote:Neil, leaving the - before the Lotus was a mistake :oops: , don't know what I was thinking :roll:
I thought it was in deference to the LEC Founder. :wink:
Return to General
Users browsing this forum: Bing [Bot] and 1 guest
