Elan SE 1991 - Roof compartment release mechanism
Postby elanseirl » Wed 10.09.2014, 13:53
Hi All,
My Elan SE has been sitting for a number of years :oops: I've finally got round to giving it some very overdue TLC, but the release mechanism for the roof/battery compartment is not releasing :?: . I've WD40'd the holding pins and the pully/bolt in the door frame but no joy :bonk:
Any and all suggestions would be appreciated.
Cheers.
elanseirl
Location: Cork, Ireland aka "The Real Capital of Ireland!!"
Re: Elan SE 1991 - Roof compartment release mechanism
Postby cliff » Wed 10.09.2014, 18:01
Welcome to LEC.
Have a look at this thread, should help you out.
viewtopic.php?f=37&t=23004&p=290189#p290189
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby elanseirl » Tue 16.09.2014, 10:57
Thanks Cliff, very much appreciated. I'll give that a go.
Cheers :D
elanseirl
Postby elanseirl » Tue 16.09.2014, 13:01
cliff wrote:Welcome to LEC.
Cliff thanks very much for the help. I expected hours to be wasted, took <20 mins. Luckily, I just had to remove screws from the locking mechanism upright post covers and pull locking rods with small pliers. Your pictures were invaluable.
Now to replace the battery, check oil and petrol and see will the engine turnover.
:cheers:
elanseirl
Postby Jamie N » Tue 16.09.2014, 21:24
It would be a good idea to turn the engine by hand first if its sat that long, there is a good chance the alternator may be seized with corrosion, check its free before you fire it up, if its solid, undo the belt and try turning it back and forward. Good luck BTW. :wink:
Jamie.
Monaco S2 #406
Jamie N
Seal God
Postby cliff » Sat 20.09.2014, 22:44
+1 for that
07 Alfa Spider 939
cliff
Users browsing this forum: SemrushBot and 2 guests
