Hi Dermont
There are some other threads here where owners have posted how to do it, for instance
THIS or
THISYou can use bicycle brake cables like I did.
These cables are normally too long, so you can cut them down to size...... I left the end that was already sealed, and routed that to the back of the car where the clamp is.
Then, on the front I made a small loop like on the original, and threaded two 4mm (depending on the thickness of the brake cables you use) nut on to the cables, and used a hammer to 'crimp' these....
Something like
I used heat shrinking tube to protect it (seeing as I had plenty in stock), others seem to use the the outer covering of electrical wires
This can then be pop riveted to the hood as per the original, or if you have no riveter, then you could use a nut and bolt.
Good luck
