Many Elan M100 New Parts (Old New Stock)
Postby Yoram » Tue 15.12.2015, 18:38
Selling parts that I have accumulated over the years. All prices in USD include shipping in the United States. I am willing to ship overseas for actual costs
Best way to reach me is email (which is my paypal email if you just want to buy and pay): ykeinan@post.harvard.edu
B100B0078F Glass Regulator Assy RH 250
A100E6031F Drive Belt-Alternator 20.00
A100M6049F Column Switch-Wash Wipe 20.00 (also for Elise/Exige)
B100M6005F Switch-Air Conditioning 20.00
A100B6151H Clip-Locking Button 4.00 multiple
B100K0028F Heater Hose Outlet 25.00
A100K0030F Heater Hose 20.00
C100B0607F Cable filler Flap Release 20
A100B6047F Rod Clips 2.00 multiple
A100R6004S Outboard Boot Kit 30.00
A100R6005S Inboard Boot Kit 25.00
E100B0759F Pod Hinge-Pod System 25.00
B100M0161F Wiper Arm RH LHD 20.00
A100E6170S Timing Belt 75.00
C100B0605F Cable-Stowage Lid Release B3 15.00
A100E6153F H.T.Cable (DIS) Set B3 100.00
C100B0460F Cable Bonnet Release LHD 40.00
A100J0027F Brake Hose-Rear Inner 15.00
B100V0052J DOOR POCKET RH 75.00
B100V0051J DOOR POCKET LH 75.00
C100J0026F Brake Hose-Rear Outer 15.00
A100E6097S Gasket-Exh Manifold/Head B3 20.00
A100E6100S Gasket-Inj Hsg/Cyl Head(5) B3 20.00
A100E6085S Oil Filter 15.00
C100F0017F Gear Shift Cable 275.00
C100K0022F Oil Cooler-524M161 C4 275.00
B100H6031S Rack Bellows Kit B3 15.00
B100M6052F Bezel-Cigar Lighter 10.00
A100E6101S Gasket-Inj Hsg To Plemum B3 20.00
A100B6171S Catch Assy-Soft Top B3 75.00
A100P0038F Switch-Trinary 30.00
B100M6041F Cigar Lighter 25.00
A100D6008F Bearing-Rear Wheel-Inner 30.00
C100C6006F Flanged Bush-Raft Mount B2. 15.00
B100M6019F Switch-Master Lighting 20.00
A100M6080F Mirror Timer Relay 30.00
B100M0110F Module-Pod Delay 18.00
B100U0253F Badge 'Lotus Design' 30.00
A100S6011F Exhaust Clamp 15.00
A100E6024S Sensor-Heated Oxygen B3 275.00
A100B6271S Centre Slide for Window Regulator (Left Door) 10.00
B100U0085F Badge 'Elan' 40.00
A100B6057F Fastex Scrivet 8mm clips for the under sheet 2.00 multiple
A100E6285S Gasket Set-Cyl Head-NA 100.00
A100M6154S Front side/indicator lamp, 85.00
A100E6562S O Ring-Plug To Head 10.00
Yoram
Re: Many Elan M100 New Parts (Old New Stock)
Postby HJ2 » Tue 15.12.2015, 20:04
I think that when the time comes, I'll sell my car in parts! ...
Postby Yoram » Tue 15.12.2015, 20:14
Yes, I have the same thought on one of my M100 :)
Yoram
Postby Yoram » Wed 16.12.2015, 14:16
Few items sold
Yoram
Postby Yoram » Wed 16.12.2015, 18:11
Active sales this morning.
Yoram
Postby lotusrepair » Thu 17.12.2015, 05:43
What is this? A100P0038F Switch-Trinary
I could not find it in the parts book.
lotusrepair
Postby lotusflasherman » Thu 17.12.2015, 10:26
lotusrepair wrote:What is this? A100P0038F Switch-Trinary
It's part of the aircon' system if that helps.
Looked it up and should be B100P0038F - Page 18.03A Item 36...
Postby Brit-Car-Nut » Thu 17.12.2015, 15:11
Actually, the correct part number has been reverted back to A100P0038F. It has been on the Aftersales List for years at £3.33.
It is a common (at least in the US) A/C single high/low pressure switch that threads on the Receiver/Drier to shut the clutch off if the pressure gets too high or drops too low.
A100P0038F is only used in the R12 system while A100P6050H is used in the R134A system.
Also note:
A100M6049F is the wiper/washer switch for the NON-SIR (ROW) cars. The switch for the SIR (FED) car is about 1 inch longer to compensate for the much larger steering wheel.
A100B6047F is the clip for the bonnet stay/rod
Postby Yoram » Thu 17.12.2015, 20:49
Thanks for the info!
Yoram
Postby Yoram » Sun 20.12.2015, 18:48
Added Few items, subtracted the ones sold.
All sold items will be shipped tomorrow.
Yoram
Postby Yoram » Sat 26.12.2015, 17:54
All purchased parts have been shipped
Yoram
Postby Yoram » Fri 08.01.2016, 18:06
bump! still have plenty of parts for sale
Yoram
Postby Scott » Sun 15.01.2017, 15:01
Hello, do you still have parts??
List some please.
1998 BMW 316 E36 Coupe
2001 Volvo S40 1.6
1991 Lotus Elan M100 Turbo
2004 Ducati Monster 620ie
Scott
Postby Yoram » Sun 02.09.2018, 01:39
Still have many of these parts. Text me at 7038632788 or email at ykeinan@post.harvard.edu
Yoram
Return to Elan Parts for Sale (New Parts For Sale)
