is there something wrong with my elan? (Fuel consumption)
Re: MOT FAIL!!!!
Postby steble » Tue 16.02.2016, 10:21
found a picture on my work PC........ handy that :)
As you can see here, it doesn't have a lambda sensor!!!!! i'll be cancelling that order then.
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Re: MOT FAIL!!!!
Postby Simon_P » Tue 16.02.2016, 14:55
Check CTS - When it goes the temperature reported to the ecu is low and the ecu richens the mixture.
Check it with elanscan
Re: MOT FAIL!!!!
Postby Brit-Car-Nut » Tue 16.02.2016, 17:03
Also, CHECK the parts source for the O2 (lamda) Sensor. The one in your eBay link has a picture of a single wire version and the M100 uses a 3 wire (pre-heated) version.
Look at Bosch 15701 for the correct one. I also found Bosch 13277 is a suggested substitution
In the US, 13277 are on eBay for $13.00 and Rock Auto lists them (use the 1991 Isuzu Impulse Turbo as the look-up) starting at $31.00 (From Denso).
Rock Auto also lists one there as a single wire version, so their information is not always correct.
The lower priced eBay item $13.00 is a MTE Thompson part and the Bosch listed is the 13277 ($29.65). I have used Herko for other parts over the years.
If it helps anyone, the Lotus Part Number is A100E6024S, The Isuzu Part Number is 8970185870 and The GM Part Number is 97018587
I have ordered one of the MTE Thompson sensors to compare it ti the Bosch I already have and will add to this post when it arrives next week.
ADDED 21/02/2016: The MTE Thompson O2 Sensor arrived and it looks to be an exact match. Wire length is not too long either.
Re: MOT FAIL!!!!
Postby Fredjohn » Tue 16.02.2016, 17:13
Brit-Car-Nut wrote:Also, CHECK the parts source for the O2 (lamda) Sensor. The one in your eBay link has a picture of a single wire version and the M100 uses a 3 wire (pre-heated) version.
John: as usual extremely detailed useful information from you and can be logged for future reference. Unfortunately steble's car does not have an O2 sensor as it is open loop: see picture above.
Re: MOT FAIL!!!!
Postby Brit-Car-Nut » Tue 16.02.2016, 17:17
Hi John: I saw that, but he also showed an incorrect O2 listing on eBay and I wanted to clarify that what he ordered wouldn't work so I listed several that will.
The MTE Thompson O2 Sensor is a good match at a much lower price.
Re: MOT FAIL!!!!
Postby Fredjohn » Tue 16.02.2016, 17:21
Brit-Car-Nut wrote:Hi John: I saw that, but he also showed an imncorrect O2 listing on eBay and I wanted to clarify that what he ordered wouldn't work but what I listed will.
:D on the ball as ever: nice one: :D
Re: MOT FAIL!!!!
Postby Andy_J » Tue 16.02.2016, 20:11
Given the low mileage (2800 miles) since last MOT, is the fuel 'fresh', If the fuel has been in the tank for a few months it can 'go off'
90H BRG SE 48,000 Miles
Andy_J
Re: MOT FAIL!!!!
Postby Candles » Tue 16.02.2016, 20:46
Nice original looking car though! Paint looks great!
I'm with Simon above - the rapid (2800 miles) change and the black plugs seem to point to a WAY too rich mixture. This could be caused by the ECU thinking the coolant is still cold. You can check the CTS with a multimeter for gross errors: It should be 185 Ohms @ 100C and high resistance when cold (the manual states 7500 Ohms at 4C). If the circuit is open it should have set a Code 14 - did you do the Paperclip Test?
Candles
Re: MOT FAIL!!!!
Postby Rambo » Tue 16.02.2016, 23:06
I can't really help with your emissions problem but when I looked at your engine bay I couldn't help thinking the coolant header tank looked empty ?? Are you using glycol coolant ? Hope its not just water :shock:
Worth a check anyway while you're having a poke about under the bonnet.
Re: MOT FAIL!!!!
Postby steble » Wed 17.02.2016, 08:22
Rambo wrote:I can't really help with your emissions problem but when I looked at your engine bay I couldn't help thinking the coolant header tank looked empty ?? Are you using glycol coolant ? Hope its not just water :shock:
I'll be honest, i've not put anything in it since i've owned it so don't know what coolant is used. it is not empty however
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Re: MOT FAIL!!!!
Postby steble » Wed 17.02.2016, 08:23
Andy_J wrote:Given the low mileage (2800 miles) since last MOT, is the fuel 'fresh', If the fuel has been in the tank for a few months it can 'go off'
fuel is fresh, it had run out when I went to start it the last time lol
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Re: MOT FAIL!!!!
Postby steble » Wed 17.02.2016, 08:28
Candles wrote:Nice original looking car though! Paint looks great!
I will give this a go! :)
Unfortunately I will not be able to touch the car to the weekend so have tried any of the above ideas yet :( I really want to get on with it! lol
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Re: MOT FAIL!!!!
Postby steble » Wed 17.02.2016, 21:35
Wooo hazard switch fixed!
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Re: MOT FAIL!!!!
Postby HJ2 » Wed 17.02.2016, 21:46
Good job! and saves a few pennies :-)
Let's fix the over fueling next!
Re: MOT FAIL!!!!
Postby steble » Thu 18.02.2016, 09:13
Yeah now the bigger issue.
If it does turn out to the the cts, where the hell do I get a new one?
Can't find one anywhere!!
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Re: MOT FAIL!!!!
Postby epipete » Thu 18.02.2016, 10:29
steble wrote:Yeah now the bigger issue.
Try the wiki http://wikilec.9600.org/index.php/CTS
It's the place to start :burnout:
Re: MOT FAIL!!!!
Postby Enright » Thu 18.02.2016, 10:51
:goodposting: :agree:
Exactly what I was about to post.
Edit: ...and it now looks as though we've nailed the cause of the cr@p fuel economy - exactly as SOMEONE previously advised! :roll:
Re: MOT FAIL!!!!
Postby Fredjohn » Thu 18.02.2016, 10:54
Beaten to it!
Really must try harder :D :D :D
Re: MOT FAIL!!!!
Postby Rambo » Thu 18.02.2016, 10:55
steble wrote:If it does turn out to the the cts, where the hell do I get a new one?
SJS :wink:
Re: MOT FAIL!!!!
Postby steble » Thu 18.02.2016, 11:22
Wow thank you now I have found loads!!
so any of these should work hopefully
http://www.ebay.co.uk/itm/NEW-INTERMOTO ... Sw3ydVwi6P
http://www.buycarparts.co.uk/metzger/1811144
and many more
YELLOW ELAN M100
SUZUKI IGNIS SPORT
steble
Users browsing this forum: Chas54 and 8 guests
