Artaban wrote:If you need to upgrade the air filter I'd go with the K&N air filter element here: http://www.knfilters.com/search/product ... rod=E-2360 £40.79 incl VAT.
I wouldn't be tempted with an induction kit which takes the air from within the engine bay as it gets mighty hot under the bonnet and you'll be drawing in hot air to the engine with a corresponding drop in power as a result.
Andy
with draw cold air from outside but would recommend ITG Racespec oiled foam filter. Mine was fitted by Kelsport as part of a major service when I first bought the car. ITG foam filter lotusflasherman wrote:Keeping the OE filter drum also allows for fitting a recirculating dump valve that takes the strain off the turbo and reduces turbo lag silently... can't stand the popping and banging of open dump valves, but some love it.
Saltire wrote:lotusflasherman wrote:Keeping the OE filter drum also allows for fitting a recirculating dump valve that takes the strain off the turbo and reduces turbo lag silently... can't stand the popping and banging of open dump valves, but some love it.
If only the recirc dump valves were easier to come by; I haven't seen a DV30 for ages now.
