by Dom » Fri 23.06.2017, 17:57
Evening, All.
I'm after the large grommet that surrounds the air intake pipe as it passes through the nearside inner wing. I'd be very grateful for a part number or a heads up as to where to source this part. Mine's in rather a sorry state!
Many thanks,
Dom
Dom
by Fredjohn » Fri 23.06.2017, 18:16
Part no A100L0077F easily available from SJ Sports Cars for £18.53 plus delivery plus VAT
Link here to SJ's
Am sure Paul Matty also sells it, but I can't find it on his website.
Check out the parts catalogue readily downloaded from brit-car-nut's signature in any of his posts, as are all the workshop manuals.
EDIT ADDENDUM:
BEATEN TO IT BY RAMBO> HIS PART NO. IS SJ'S ALTERNATIVE, MINE IS THE ORIGINAL LOTUS PART. THE SAME PART THOUGH. PAYS YER MONEY TAKES YER CHOICE
by Dom » Fri 23.06.2017, 18:22
Thank you very much!
Dom
by Rambo » Fri 23.06.2017, 18:27
In case there is any confusion, Fredjohns link is to the correct pukka Lotus part and my link is to the cheaper SJ option
Both will do the same thing ie perish and look knackered after a few years
My NMY uses a cv boot and does the same thing and is a good way of saving even more beer tokens
- Don't push me
by Saltire » Fri 23.06.2017, 22:09
I've had both the SJ part and the eBay "Austin Healey" part (I know, made of money). In my view, the AH part is much stronger and a better fit, although it does need a bit of encouragement/lubrication to get it into place
by ragtime » Fri 23.06.2017, 22:13
Ive also used the AH part,it fits fine.
ragtime
by lotusflasherman » Fri 23.06.2017, 23:46
I found the AH ones about 10 years ago and have used them since on both my SE's. They seem to be recently made to pattern and have lasted much better than Lotus ones.
Paid a lot of money for "a proper Lotus one' from Stratton Motors when it was still on the factory parts list and found it didn't last 6 months before it had perished and fallen to bits. Rubber had grey and powdery surface straight out the bag so I suspect it was made when the M100 was still in production so I'd say avoid Lotus ones, they will be OLD !. SJ's alternative may be newer but it's twice the price of the AH..
PS.. easy to fit them when rubber is warm ...
by Saltire » Sat 24.06.2017, 08:28
lotusflasherman wrote:PS.. easy to fit them when rubber is warm ...
Yes, I just stuck mine in some hot water for a few moments, dried it off and it was much more flexible.
I did consider the blowtorch I use for cooking, but only in passing
by Rambo » Sat 24.06.2017, 08:59
My rubbers are always warm
- Don't push me
