I've ruined my car..........
Re: I've ruined my car..........
Postby GeoffSmith » Sat 27.10.2018, 17:08
simonbuk wrote:Ok thanks. Part 22 is clearly missing !
I think it's the last piece of the jigsaw. Although I do still have an electrical connector not connected to anything !
Confirm that the S2 has two hoses to the plenum. I replaced my reservoir hose with silicone and didn't bother with the right angle POS. Where is your connector?
Postby simonbuk » Sat 27.10.2018, 17:45
Picture of connector on page 2. Comes from around the back and under the plenum, almost looks like a temp sensor or something.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby GeoffSmith » Sat 27.10.2018, 18:51
Can't make out much from the picture. What colour are the wires?
Postby Simon_P » Sat 27.10.2018, 18:55
Looks like the plug for the EGR valve and should not be connected ... Unless your car was made for the Japanese market.
Postby cliff » Sun 28.10.2018, 14:48
Hi Simon,
Might be a bit late to help. I had the first Piper downpipe, the car drove really well after with occasional overboost until I had the turbo ported.
A couple of pics from the rear of the engine might help, mine is an SE though.
Useful diagrams from the closed loop manual.
Vacuum Connection Diagram.pdf
EGR.pdf
Good luck
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby simonbuk » Sun 28.10.2018, 16:31
Yes, thank you. Up and running with just a couple of vacuum connectors needed to finish it off.
Apart from a bottom end rebuild needed...…………..
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby lotusflasherman » Sun 28.10.2018, 17:00
Bern wrote:They look like gas type fittings (we use them at our Glastonbury Festival food stall on the gas rings, burcos etc).
We have a crimp tool to fit them, and I always remove them with a hacksaw by cutting carefully through the crimp!
Blimey, you like hard work. :lol: If you have the correct crimp pliers just turn them through 90° and cut off the crimped flange. That is the correct method which is why they have long handles to provide plenty of leverage.
Using a hacksaw risks damage to the hose so is not considered a Safe System of Work for a business. (Do what you like privately.. :lol: )
Available on ebay for £15.50. Crimps-Gas-Fittings-Pliers
(The link shows the picture but go down the menu for the price.)
Postby cliff » Sun 28.10.2018, 23:21
simonbuk wrote:How do you get these clips off ?! Are they crimped on and you have to break them to get them off ?
Screwdriver usually to open them enough to break them or give purchase for sidecutters. Not much room for a hacksaw on many cars let alone the M100
07 Alfa Spider 939
cliff
Postby cliff » Sun 28.10.2018, 23:22
Simon,
good you are almost there. :burnout:
07 Alfa Spider 939
cliff
Postby HJ2 » Mon 29.10.2018, 10:52
Have a read here as well Simon.
perhaps it helps!
Postby simonbuk » Mon 29.10.2018, 11:05
HJ2 wrote:Have a read here as well Simon.
perhaps it helps!
Link ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby HJ2 » Mon 29.10.2018, 11:15
