)Simon_P wrote:John, what do you put in in the UK?
Phil, just trying to think what may be affected by Ethanol? The Tank is plastic, as is the fuel pipe. The Rubber bits are the fuel pressure regulator, injector O ringsand the fuel rail hoses. I don't suppose Lotus did any testing to reach that conclusion, and presume that it is based on the materials in use at the time.
Dave Eds wrote:95 Ron but not from supermarkets
lotusflasherman wrote:Dave Eds wrote:95 Ron but not from supermarkets
You will probably be getting 5% Ethanol then ... possibly 10% ..
Esso website says this
"The majority of unleaded 95 Octane petrol sold in the UK contains up to 5% ethanol as required under the Government’s Renewable Transport Fuels Obligation (RTFO).
There is currently no requirement for renewable fuel (such as ethanol) to be present in super unleaded (97 grade petrol).
Esso super unleaded petrol (Synergy Supreme+ Unleaded 97) is ethanol free (except in Devon, Cornwall, the Teesside area and Scotland). We would therefore advise anyone who has concerns about the presence of ethanol in petrol to use Synergy Supreme+ – providing they do not fill up in Devon or Cornwall, the Teesside area or Scotland."
so 'tough luck' to those in 'Devon or Cornwall, the Teesside area or Scotland'..
I fill up with what is delivered through said pump. Now I know this is England and not Europe, or
lotusflasherman wrote:lotuscars.com/fuel-compatibility/
Mmmm, so that is more or less what is written in the Esprit owner manual too. So it's not really compatible. OK it shouldn't damage the engine but still it's not that good ...Ethanol E5 & E10 – A mixture of 5% or 10% ethanol (grain alcohol) and unleaded petrol may be used on Evora, but the lower octane rating (typically 93 – 94 RON) will result in slightly reduced performance and economy. If driveability problems are experienced as a result of using ethanol, use 95 RON unleaded petrol. Do not use Ethanol blends with a higher concentration than 10%. Methanol – Do not use fuels containing methanol (wood alcohol). Use of this type of alcohol can result in performance deterioration and damage to critical parts in the fuel system.
tigerdog wrote:Well, the Lotus fuel-compatibility link is a bit disconcerting. E10 has been mandated in the USA since 2012, California since 2010. Smaug has been drinking it for nearly 10 years! No issues I can see, but now I have one more thing to worry about.
. CO2 emissions also increased !! lotusflasherman wrote:ethanol does not have the calorific value of petrol (gas to you), down about 30% on petrol, so E5 gives worse mpg than petrol and E10 even worse...
Simon_P wrote:I wrote a long (Dapinkyesque) explanation a couple of days ago but it doesn't seem to have been posted - My error I expect.lotusflasherman wrote:ethanol does not have the calorific value of petrol (gas to you), down about 30% on petrol, so E5 gives worse mpg than petrol and E10 even worse...
In essence - Ethanol has less energy than Normal petrol as Phil mentions and It is also an Octane booster (110). We traditionally think of petrol and buy it in terms of Octane rating but adding ethanol means that you can put lower grade petrol in and boost its octane so you get less of the good stuff to start with and less energy but you are paying the same. The science is that Higher octane fuel resists knock and can achieve higher cylinder pressures = more power. But the Elan is designed for 95 so you are unlikely to see the benefit - Keep collecting the Nectar points Dapinky.
The next traditional measure of petrol is fuel efficiency (MPG). Ethanol has about 30% less energy so E10 has about 3% less and you could expect 3% less MPG.
What most people miss is that less energy means less power (its not quite as simple as this) and 3% on an at the top end of an elan is about 5 BHP and the power loss will be across the range not just at the top end. So on the days when you want to accelerate faster buy the good stuff.
The rest of my long response was about Germany's lack of oil reserves driving the EU's need for Bio fuels which require the rainforests to be dug up to produce enough.
