Quantum2001 wrote:Great thanks for the quick reply, I'll go and have a look, the CO readout on the MOT says 'cat equipped vehicle with closed loop control', however I don't know if that is correct or not.
alan e wrote:Quantum2001 wrote:Great thanks for the quick reply, I'll go and have a look, the CO readout on the MOT says 'cat equipped vehicle with closed loop control', however I don't know if that is correct or not.
BCN If its a MOT it must be in the Uk and the tester is using the wrong data its not got a cat this happens a lot here take it back to get it re tested using the right data evan if its been changed to closed loop its still tested has a none cat car ie a 92se.
Brit-Car-Nut wrote:alan e wrote:Quantum2001 wrote:Great thanks for the quick reply, I'll go and have a look, the CO readout on the MOT says 'cat equipped vehicle with closed loop control', however I don't know if that is correct or not.
I understand, but just wanted to explain the possibilities. I know the '92 and newer cars have the O2 wiring completely available without any special work, so there would be no other indication of someone just adding an O2 and 1499 chip to get better fuel economy.
Quantum2001 wrote:Sorry, yes I should have been clearer, I am in the UK. I'm just waiting for the anti-seize to work on the bolts holding on the turbo cover and then I'll be able to tell. I've had issues before with one of my kit cars where they tried to test it to the wrong standard because it didn't come up on the DVLA system.
The washers on the car have been changed to work with a toggle switch instead of the stalk and I told the tester this and he still failed it on this. I tried it when I got home and it worked fine. I'm planning to change it back to work with the stalk and am guessing there is something wrong with the switch, would I be write in thinking the stalks are 1980s Cavalier/Astra? I can't see them listed on the compatibility chart I have.
Regards,
Russell
Saltire wrote:I would also think carefully about where you take the Elan for its MoT. In my experience many run-of-the-mill MoT stations aren’t willing or competent to test classic cars. I’ve been told on several occasions “not to bring it back because we can’t cope”.
On emissions, when I had my Alfa Spider, one tester failed it. I took it with no adjustments to my local “shed”, run by a pensioner with oily fingers, and he passed it. I asked him to explain, and he said “Look, it’s a 1972 car. I start it up, and if I can see the garage wall through the cloud of exhaust smoke, it’s fine”![]()
My last MoT emissions result on my S2 is here.
muley wrote:Saltire wrote:I would also think carefully about where you take the Elan for its MoT. In my experience many run-of-the-mill MoT stations aren’t willing or competent to test classic cars. I’ve been told on several occasions “not to bring it back because we can’t cope”.
Good post. My local MOT man is a legend. E.g. small exhaust leak gummed up on the spot . He spots a fail and says he knows I'll fix it a s.a.p. The best one recently ~ can't test the brakes on a roller due to LSD fitted ~ just stands on brake pedal as it comes of the stand = pass.
