What are these parts??
Postby Lotussi » Mon 30.09.2019, 17:02
Hi All,
In my purchase of a Lotus Elan, with the motor out
and parts in boxes, trying to solve the puzzle, some items we can not identify...
These items are pictured below:
does anyone of you experts know
-What are they?
-Where do they go?
and can anyone send me a picture of what goes underneath the car, right in the middle here? photo 3
Lotussi
Re: What are these parts??
Postby Steve A » Mon 30.09.2019, 17:41
I believe the bottom bracket goes on the engine block, just to the left of the dip stick, turn the bracket 90 degrees anti clockwise (as in your photo) with the short leg of the "L" against the block.
Postby Steve A » Mon 30.09.2019, 17:44
The top photo is the brackets that support the seats,
The middle is an engine steady.
Postby Giniw » Mon 30.09.2019, 17:44
download/file.php?id=26615&t=1 is the engine torque damper.
It goes on the engine block on one side and on the front of the prongeron on the other.
Giniw
Postby Lotussi » Mon 30.09.2019, 18:05
Hi Giniw,
Does 2 of these prongerons go in?
Lotussi
Postby Giniw » Mon 30.09.2019, 18:12
Only one prongeron, it's the grey T shaped thing that goes from the chassis front cross member to the underneath of the radiator.
https://scontent-cdg2-1.xx.fbcdn.net/v/ ... e=5DFB0BFB
You can see a screw with two washers towards the top (=front when in the car) of it. It is the screw used to attach the damper.
edit: just found a better set of photos (I couldn't find it because it's misspelled in the ebay description)
https://www.ebay.co.uk/itm/LOTUS-ELAN-M ... 2570617767
Giniw
Postby Simon_P » Tue 01.10.2019, 01:29
Lotussi wrote:and can anyone send me a picture of what goes underneath the car, right in the middle here? photo 3
That looks like the mounting flange on the exhaust pipe for a mass damper.
https://kelvedonlotus.co.uk/product/mas ... r-exhaust/
Postby Lotussi » Tue 01.10.2019, 09:46
Hi Simon_P, Giniw, Steve A,
Thank you!!
and thank you for the links
will continue work tonight and let you know the result!
Lotussi
Postby Lotussi » Thu 10.10.2019, 13:29
Thank you for your answers
we got the engine to run- yeah :)!!
-we still have other little issues
anyone has a photo of the speedo drive gear attachment piece?
Lotussi
Postby John_W » Thu 10.10.2019, 16:55
I don’t think I’ve ever seen a photo of it, but you don’t need one as the service notes has the picture below that shows it clearly.
You just need a flat piece of metal of the correct size (approx 2cm x 1.5cm) with one or two of its corners rounded and a hole for a mounting bolt drilled in the correct place to allow it to swivel out of the way to allow the speedo drive to be removed, then to swivel back on top of the circular part of the drive and abut against the square bit of the drive to hold the speedo drive in place when the bolt is tightened. Do NOT tighten the bolt too much or you will strip the thread in the alloy.
Postby Lotussi » Wed 16.10.2019, 17:02
Thank you!
Lotussi
Users browsing this forum: Google [Bot] and 5 guests
