Simon_P wrote:If you changed it yesterday it sounds like you have an airlock and need to bleed the system.
Thought I got all the air out - good shout will check this if the rain ever stops
GeoffSmith wrote:The CAS fault appears at about 434½s and the EST fault at about 436½s however there is a glitch in the coolant temperature reading at about 432½s and the battery volts drop between 440 and 448s.
I wonder if there is an intermittent connector or earthing issue somewhere.
GeoffSmith wrote:EST = Electronic Spark Timing.
GeoffSmith wrote:The EST is the plate with the coil packs so all to do with the ignition circuit. It may be a red herring if there is an intermittent wiring problem which may be what is indicated by the raw coolant signal dropping out.
Until you get the base timing set, I wonder whether it is worth retarding the ignition a touch to try to get rid of the knock. Taking a log every time you drive would be a good idea. Don't worry about the odd ElanScan error message - it is capturing the data at 5 per second with is close to the limit and the loss of one or two data points is neither here nor there.
Brit-Car-Nut wrote:Martin,
Maybe you should you check the Ignition Control Module for corrosion and other connectivity issues due to leakage or "splash" at the coolant tank?
It is not uncommon and often can be cleaned and put back into service.
It is the flat plate component that the coils are bolted to. It is directly under the coolant tank.
If nothing else, you could carefully disconnect the three connectors and look at the connections to see if they are getting cruddy.
If not, you can plug them on and off a few times to "clean" the connections and spray a bit of WD40 on them.
Brit-Car-Nut wrote:If the connection pins were clean, then you probably don't have to check again, but if you are not sure, just clip them on and off a few times.
It is a lot easier to do that on a UK car since the steering column and brake master cylinder isn't in the way.
Were the coil packs replaced because of a running problem or did it run OK and you were just replacing old coils?
By the way, SW Lotus has the best (lowest) price for the Hall Effect repair kit. They have gone obsolete.
texas2201 wrote:Yeah I can do that - I had it off when I put the new coil packs on about 2 months ago. No harm doing it again.....well when the rain stops
