Broke down today, wont start
Re: Broke down today, wont start
Postby Rambo » Mon 21.06.2021, 19:18
BertBeck wrote:Just had the new CAS assembly fitted and everything seemed ok to start with, no mis fire or anything but went for a longer drive today and somethings not right.
Whenever I had to stop the engine kept cutting out, wouldn't idle and engine mgmt light coming on but restarted each time.
Also speedo not working. The needle just bobbing around between 0 - 10 mph.
Any ideas anyone?
So, what error code(s) did you get ?
Postby BertBeck » Mon 21.06.2021, 23:05
Thanks for reply. Speedo not registering anything now.
Took binnacle off dash and checked cable is tight in back of speedo.
Arm down the back of engine to check cable is not loose at gearbox and retaining plate seems to be present and tight.
Then disconnected cable at speedo and drove car while son looked down cable end to see if its spinning but its not so can only assume cable is broken. Still having problems with cutting out at idle and mgmt light coming on.
Did paper clip test and flashing fault code 12 which is no fault?
We all think we're Rod Stewart
BertBeck
Postby tb10 » Mon 21.06.2021, 23:15
Yes, it sounds like the cable has broken in that case. Not sure if the availability or part cross references?
tb10
Postby BertBeck » Tue 22.06.2021, 00:15
Just checked the wiki, SJ Sports cars have the cable, gear and spare O ring.
£85 the lot. It seems that when the cable is broken or faulty the speed sensor cant detect movement so that affects the ECU causing stalling.
BertBeck
Postby Rambo » Tue 22.06.2021, 07:21
This might help you with the removal and refitting
http://wikilec.com/view/Speedometer_Cable
Postby BertBeck » Wed 23.06.2021, 19:42
Cheers :)
BertBeck
