by Malc » Sat 23.04.2022, 20:24
Can’t see any up to date info on this - last post seems to be 2017. Is it possible to install aftermarket air con into an S2? I’m not looking at installing original Lotus/GM parts just putting in modern air con. There is a company in Surrey that install air con retrospectively and I am awaiting a response from them but wondered if members knew of a company who currently does it. I had heard that Barry Ely in Essex did it and will speak to them when possible but thought I’d ask the knowledgeable! Thanks all.
Malc
- Tinkerer
by Simon_P » Sun 24.04.2022, 08:23
I don't know where you are based?
It wouldn't be that hard as there was space for it as an option...not much space! The wiring is in the loom, most components could be generic and flexible hose could be used to avoid some of the torturous routings of the factory set-up.
The only bit that you will see, and dead handy as it plugs straight in is the switch, which is still available - I have a new one that you can have for £10.
by Malc » Sun 24.04.2022, 12:18
Thanks Simon. I’m also in Kent, just north of Sevenoaks. Even though I haven’t yet found anyone/anywhere to do the installation, it would be good to have the switch, if it is going spare, even if I don’t actually get it done in the end. If you could post it to me, i am happy to pay for the switch and postage, or if you are near, I could pop over and pick it up. Cheers, Malc
Malc
- Tinkerer
by Malc » Sun 08.05.2022, 19:24
Just heard from a company that installs air con retrospectively. They haven’t done an M100 before (surprise!) but estimated £4,000 to £4,800 to fit. So naturally I’m going to do that….
. Actually I think I’ll take the roof off more often.
Malc
- Tinkerer
by Simon_P » Sun 08.05.2022, 22:03
Hi Malc.
PM your details if you would still like the switch.
Malc wrote:They haven’t done an M100 before (surprise!)
Therein lies the problem. I don't suppose that it would be cheap but £4k sounds a bit high.
by Rambo » Mon 09.05.2022, 10:00
Why bother in this country? I had air con as OEM in my 1st Collapso Red Elan. It never got used. It's much nicer gettting the top down and the wind in your hair.
I think Lotus put the wiring in the loom more for our cousins in warmer countries
- Don't push me
by Simon_P » Tue 10.05.2022, 22:22
A/C is great for clearing the screen on a wet day.
by Malc » Sun 15.05.2022, 18:37
As a matter of interest, got a second quote to install aftermarket air on - £4,500 plus VAT from Alpine Air. Wow.
Malc
- Tinkerer
by Malc » Thu 19.05.2022, 12:50
[quote="Simon_P"]Hi Malc.
Simon - have PMd you.
Malc
- Tinkerer
Return to Heating and Cooling
