by dapinky » Sat 01.07.2023, 13:15
Clive, there is (just!) enough cable length to allow you to prise the switches out of the centre console and then separate the wiring connector (4 wires in a plastic plug) - it is a straight pull-apart, as there are no locking clips on the joint.
I am assuming that your talking about an S2, because if you can lift the console without previously removing the switches to gain access to 2 setscrews holding down the console on an SE/NA then something is broken!!!!
