Hose joints
Hose joints
Postby rob/d » Thu 06.07.2023, 07:44
I noticed a crusty deposite on my hose joint near the thermostat .
Split the hose and found this fun piece of aluminium.
It was weeping , but could have let go at any time . Lower joint near the " Y " piece was the same .
Replaced with some stainless ones now.
rob/d
Re: Hose joints
Postby FunElan » Thu 06.07.2023, 15:52
those are pretty crusty!! I think the one time a shop worked on my car (to install silicon hoses), they changed this piece out for something that was plastic and over the counter.
FunElan
Re: Hose joints
Postby rob/d » Thu 06.07.2023, 20:12
Two of these from Ebay fixed the issue for £5, nice and heavy stainless steel .
The old ones were tin foil thin in places , i don't think they were rated to last nearly 30 years .
rob/d
Re: Hose joints
Postby chrism » Thu 06.07.2023, 21:38
Yep, there's one of these that disintegrates in the same way situated in the middle of the hose that feeds into the heater control valve - at the top of the pic:-
Believe me, it weeps after 32 years or so... :(
The current replacement hose is the one below below and costed me about £70 by the time it dropped on my doormat :shock: so I wish I'd known about these inserts at the time. I found I needed to replace the control valve at the same time since it fell apart in my hand, so I suppose the weep did me a favour - albeit an expensive one :|
Btw what size are they and what are they called? I'll be able to keep the hose 'on the shelf', now...
edit: I reckon a plastic connector (like that heater control valve) would be a longer-lasting method to join these pipes?
chrism
Re: Hose joints
Postby rob/d » Fri 07.07.2023, 10:28
I measured them at 17mm and 75mm long .
Closest i could find in stainless steel was 17mm and 55mm , which is plenty long enough .
I replaced my heater valve 7 or 8 years ago with the plastic Volvo one , but i still have the original as it was in a surprisingly excellent condition .
Ebay .There are 2 in the box.
https://www.ebay.co.uk/itm/195674046648 ... p_homepage.
rob/d
Re: Hose joints
Postby chrism » Fri 07.07.2023, 11:35
That's brilliant rob/d.
I'd advise anyone 'doing' the Volvo heater valve upgrade to look at that hose join as well - and your solution might save loadsa people having to buy the expensive 'all-in' hose update.
Thanks, I'm certainly going down your route to keep that hose as a useful spare...
edit: this pipe joiner is 14mm(dia) x 70mm and looks exactly the same as yours...
chrism
Re: Hose joints
Postby Tuga2112 » Sat 08.07.2023, 17:57
rob/d wrote:I measured them at 17mm and 75mm long .
i wonder if there is an aluminium alternative that would be more affordable.
nothing wrong with that price per se. but this mornign i bought a driveshaft bearing for less than this stainless tube. so it certinaly feels expensive considering the complexity of shape and amount of material used to fabricate
Re: Hose joints
Postby chrism » Sat 08.07.2023, 22:36
Point taken Tuga. In the end with my (smaller) heater hose aluminium insert I decided to clean up the old part with wet 'n dry and jubilee-clip it back into place to make up a spare hose. - It keeps this poorly-designed original hose as a 'reasonable' spare without throwing money at something I'm hoping not to have to use.
And yes, we ought to shop around and share knowledge of good, v-f-m m100 parts.
chrism
Return to Heating and Cooling
