by Simon_P » Wed 16.08.2023, 09:09
MoT next week and I've noticed that a mouse has nibbled a hole in the rear anti roll bar gaiter. It looks like the gaiter has a skirt onto the body of the joint which my standard replacement ball joint gaiter doesn't have. Anyone have or know of a suitable replacement?
by Simon_P » Wed 16.08.2023, 19:28
Or even the key dimensions so that I can order something that may fit
by Simon_P » Fri 18.08.2023, 09:23
Large diameter inner 30mm
Small diameter inner 16mm
Height 25mm ish
Simon_P on Fri 18.08.2023, 10:17, edited 2 times in total.
by Fredjohn » Fri 18.08.2023, 09:42
Simon
Do you mean this part:
https://www.sjsportscars.com/parts-and- ... D6024F.htmNot available separately.
EDIT CORRECTED LINK
Fredjohn on Fri 18.08.2023, 11:13, edited 1 time in total.
by Simon_P » Fri 18.08.2023, 10:06
FredJohn,
I meant the rubber gaiter for this:
https://www.sjsportscars.com/parts-and- ... D6024F.htmie I need the bit that costs £4 not £40.
Edit - the first time I clicked on your link I got a list of part numbers with no description that said R/B or NLA - thought you were pulling my leg!
by Fredjohn » Fri 18.08.2023, 11:15
Simon
Corrected link.
Looking at original parts catalogue, the rubber bush does not appear to be available separately.
Hence your question I guess!!
by RonR » Fri 18.08.2023, 11:17
The ones I have on the shelf (from SJs) are 30mm lower dia x 14mm upper dia x 23mm high.
by tigerdog » Fri 18.08.2023, 18:09
by Simon_P » Fri 25.08.2023, 12:04
Thanks for the replies. I had a normal one of the correct dimensions (like the one in Tigerdog's link) and I have put that on as a temporary measure. It needs to have the wider part of the bellows higher up hence the "skirt" on the original.
I'm looking for a more suitable replacement and will post when I find one.
