Shock absorbers.
Shock absorbers.
Postby sheriff464 » Thu 19.09.2024, 22:12
Hi, MOT time yesterday; Shock absorber has a serious fluid leak Offside rear! What would the closest to OE be for an S2.? Would it be advisable to renew the springs at the same time? Also to do both sides,even though the NSR is bone dry! All suggestions appreciated. Clive.
sheriff464
Re: Shock absorbers.
Postby Tuga2112 » Thu 19.09.2024, 22:40
cheapest possible option.
single used shock from scrapyard.
sensible budget option is probably the GAZ struts that pinky installed, which i have follwoed suit. pair for the rear.
my personal recomendation would be to do all around. so you get a fresh start, and you know you dont need to worry about them.
springs are optional. as far as im aware. their "streight" doesnt change over the years, but they will drop over time giving you a lower ride than factory (which most people prefer)
Postby sheriff464 » Fri 20.09.2024, 21:32
Thank you, Tuga for the information and advice.
sheriff464
Postby FunElan » Mon 23.09.2024, 17:54
GAZ struts are an easy install, especially if you're re-using your old springs. How stiff they should be set to might be your preference/change over time!
FunElan
Postby sheriff464 » Mon 23.09.2024, 20:33
Thank you FunElan for that. GAZ struts is what I'll go with,as I intend to keep the original springs! Regards, Clive.
sheriff464
Postby FunElan » Mon 23.09.2024, 21:51
sheriff464 wrote:Thank you FunElan for that. GAZ struts is what I'll go with,as I intend to keep the original springs! Regards, Clive.
this might help: https://www.youtube.com/shorts/6ACKKO_wjJs
FunElan
Postby sheriff464 » Wed 09.10.2024, 16:00
Fun Elan, picking up from your video on GAZ struts assembly; do I see that you have rubber boots installed on yours? Is it essential to have these? Cheers,front Clive.
sheriff464
Postby FunElan » Wed 09.10.2024, 17:34
sheriff464 wrote:Fun Elan, picking up from your video on GAZ struts assembly; do I see that you have rubber boots installed on yours? Is it essential to have these? Cheers,front Clive.
I reused the rubber boots from the old strut. They help keep dust/grime out so you should reuse if you can!
FunElan
