Luddite!dapinky wrote:The dowels can be removed with a hammer and chisel,
Simon_P wrote:There's a long oilway which has a pressure relief valve in it the welch plug is an unusual size 16mm? I have a packet of them if you need one.
The head looks pretty good should clean up. Unlikely that valves will need more than lapping.
The valve stem seals often come the wrong size - too big, should be a tight fit that you have to tap on - if you get good ones can you note the part number
no, it's more about the cleaning after.jamherber wrote:Will the pressure relief valve need removing for the machining? If
no! They should fit tight with a click and a good hard pull to remove them. Worth trying the first one on strip down.jamherber wrote:maybe something like a small amount of silicone sealant applied to them to help retain in position?
