Head removal
Re: Head removal
Postby Simon_P » Tue 01.10.2024, 22:52
dapinky wrote:The dowels can be removed with a hammer and chisel,
Luddite!
Re: Head removal
Postby jamherber » Wed 02.10.2024, 17:48
Simon_P wrote:There's a long oilway which has a pressure relief valve in it the welch plug is an unusual size 16mm? I have a packet of them if you need one.
The head looks pretty good should clean up. Unlikely that valves will need more than lapping.
The valve stem seals often come the wrong size - too big, should be a tight fit that you have to tap on - if you get good ones can you note the part number
Thanks for this info - really useful. Will the pressure relief valve need removing for the machining? If so I may well come back to you about the welch plug.
The valve stem seals I have came from SJS and are blue in colour. I'll prewarn the guy doing the head - maybe something like a small amount of silicone sealant applied to them to help retain in position?
jamherber
Re: Head removal
Postby RonR » Wed 02.10.2024, 20:19
FYI The ones I got from Rock Auto were the correct size - ENGINETECH S475V (S475V-20) Valve Stem Seal (set of 20)
Re: Head removal
Postby Simon_P » Wed 02.10.2024, 20:34
jamherber wrote:Will the pressure relief valve need removing for the machining? If
no, it's more about the cleaning after.
jamherber wrote:maybe something like a small amount of silicone sealant applied to them to help retain in position?
no! They should fit tight with a click and a good hard pull to remove them. Worth trying the first one on strip down.
Return to Engine
