Hector2021 wrote:How about if you remove the thermostat but replace the housing and then run the engine with the top hose disconnected (or loose enough to allow leakage) Obviously dont run it until it gets hot, but it should show if the main pump is forcing coolant through the engine?
The flow rate might suggest between a duff pump and a good pump depending on how well it outputs coolant.
Tuga2112 wrote:i cant see because the picture is too small. but my guess given the location is that its the one that connects at the bottom of the power steering pump.
Wevster wrote:Hi All
I've spoken to the garage that did the job originally, and they bought most of the parts from Classic Team Lotus in August 23. So, I gave them a ring and spoke to their parts dept and they informed me that they haven't had any issues before regarding this pump. I was told that they are sourced from a UK supplier but I don't know where they are made. Hopefully its a one off defect and not a batch defect. I'll have a look at the new pump when it arrives (hopefully today) and then fingers crossed, just got to fit it!
