by AJSGSE1990 » Mon 29.06.2026, 19:24
Hello, am struggling to find the spec of the Tell Tale lights, as far as I can see the bulbs are T5 but the holders come in all sorts of sizes. The base is 12mm which is a T.47 apparently. Has anyone bought from these peeps?
https://www.classiccarleds.co.uk/produc ... dd70&_ss=rThanks,
Andrew.
AJSGSE1990
- Tinkerer
by Fredjohn » Mon 29.06.2026, 19:59
Sorry, don't know what you mean by tell tale lights, but might be worth looking at Light Bulbs in wikilec
by stevie-a » Mon 29.06.2026, 20:03
What is Tell Tale light?? Edit:
A google said dash lights, i have never heard the term Tell Tale light...
stevie-a
- Tinkerer
by AJSGSE1990 » Mon 29.06.2026, 21:19
Fredjohn wrote:Sorry, don't know what you mean by tell tale lights, but might be worth looking at Light Bulbs in wikilec
The little twist bulbs holders that light up the dash indicators such as brake warning, indicators, and low battery etc. I can find the bulbs themselves but not the lamp holders as I cannot find dimensions of the products sold.
Cheers.
AJSGSE1990
- Tinkerer
by AJSGSE1990 » Mon 29.06.2026, 21:21
stevie-a wrote:What is Tell Tale light?? A google said dash lights, i have never heard the term Tell Tale light...
That's the one. Cheers.
AJSGSE1990
- Tinkerer
by rip » Tue 30.06.2026, 13:45
A word of warning about the indicator light: current flows through it in opposite directions depending on which side you are indicating.
This is fine when you use a bulb, because it works in either direction.
A LED only works 1 way though.
by AJSGSE1990 » Tue 30.06.2026, 13:52
rip wrote:A word of warning about the indicator light: current flows through it in opposite directions depending on which side you are indicating. This is fine when you use a bulb, because it works in either direction.
Absolutely, thank you. I am doing a full rewire with PDMs so at the moment only really need those plastic holders. I might just end up using push through 8mm units, next I need to try and frost the LED bulb to get them a bit more diffused.
Cheers.
AJSGSE1990
- Tinkerer
by peteoddcar » Wed 08.07.2026, 12:51
I’ve used Classic LED many times a few years back - decent quality and engineered in Uk by the owner. Probably the only place I’d go for LED conversions.
peteoddcar
by AJSGSE1990 » Thu 09.07.2026, 21:43
peteoddcar wrote:I’ve used Classic LED many times a few years back - decent quality and engineered in Uk by the owner. Probably the only place I’d go for LED conversions.
Purchased and they fit perfectly.
Cheers.
AJSGSE1990
- Tinkerer
by stevie-a » Fri 10.07.2026, 09:30
I did my triumph many years ago with the dash lights to LED another word of warning do not change the battery indicator to LED is this will cause an error leave it with the standard bulb
stevie-a
- Tinkerer
by AJSGSE1990 » Fri 10.07.2026, 09:58
stevie-a wrote:I did my triumph many years ago with the dash lights to LED another word of warning do not change the battery indicator to LED is this will cause an error leave it with the standard bulb
Understood, thanks.
AJSGSE1990
- Tinkerer
