New ECU add-on boards available - Form an orderly queue!
Re: New ECU add-on boards available - Form an orderly queue!
Postby chrism » Thu 09.04.2026, 12:12
Yes I'm running one of RonR's dual chips in my 9239 SE, added the extra wires, an O2 sensor and went full 1499. Best mod ever imo :D.
And yes, you're not alone in falling foul of those 'dinosaur' rear brakes. Jamie does a Honda type-R rear caliper upgrade - and the prospect of handbrake fail is now no longer an issue either...
Always good to get feedback too. :D
chrism
Postby LarsM1001991 » Fri 10.04.2026, 13:39
RonR wrote:Noah,
I'll PM you with more info & details.
CAS: In the M100's distributor-less ignition system the Cam Angle Sensor (CAS) sits on the end of the exhaust cam and sends signals to the ECU as the cam rotates. The ECU then decides when to fire the coils and how much fuel to inject. The timing's set by putting the ECU into service mode and rotating the CAS until the engine fires at 16 degrees BTDC.
BTW You don't need to set the CO Pot if you're Closed Loop, S2s don't even have one fitted.
Hi RonR.
please PM me as well for the information you need from me, so i can purchase the correct chip for my 1991 Elan. looking forward hearing from you, Br. Lars
LarsM1001991
Postby LarsM1001991 » Sat 11.04.2026, 10:10
Hi RonR
i'm really interested in getting one of your chips, please PM me for the details you need to proceed the order.
Br. Lars
LarsM1001991
Postby LarsM1001991 » Tue 14.04.2026, 08:28
Hi RonR.
I'm very interested in buying one of your chips as soon as possible, can you PM me for the car details you need to compleate the purchase :m100:
Br. Lars
LarsM1001991
Postby Dtjonesy » Tue 12.05.2026, 13:50
MOT update, fitted new rear brake pads, adjusted calipers and cables
Passed with 20% efficiency so all good for the summer.
Ordered the Honda kit from Jamie so will fit before the next MOT
Thanks to all for help and feedback
This is a great community
Dtjonesy
Postby pte123 » Sat 24.10.2026, 15:49
Hi Ron. I’m interested in a chip for my Fed car if you can DM me the deets. Thanks Phil
pte123
Postby MaidstoneSports » Tue 10.11.2026, 18:30
Hi Ron,
I have several M100 customers who are looking to convert to the later chip and O2 sensor format. Would you be able to supply me with a couple chips?
Kind regards
Will
Maidstone Sports Cars
MaidstoneSports
Postby RonR » Wed 11.11.2026, 17:43
Hi Phil,
I sent a PM on 6th Nov, please check your inbox.
Postby JimmyB » Wed 11.11.2026, 19:25
Hi, I'm pretty new here. My BRG Elan has failed its MOT on CO2. I'm very keen to get hold of an Everest chip as I try to get it back on the road. To misquote a certain fictional princess 'help me RonR, you're my only hope'
James
JimmyB
Postby RonR » Thu 12.11.2026, 12:36
Hi James,
Assuming your car's an SE, not an S2:
Sometimes MOT stations wrongly test emissions for SEs according to the data for S2s which are much stricter as they were fitted with catalytic converters, so please make sure the test was carried out with reference to the Pre-August 1992 specs.
First thing to try is the CO Pot adjustment procedure: https://wikilec.com/view/CO_adjustment It will need to be adjusted with an exhaust gas analyser.
If the pot's at minimum and the CO's still too high, maybe a 9930 prom would help. It adjusts the range of the CO Pot at idle so that lower emissions can be dialled in.
An Everest chip in itself won't help with CO readings, a 'closed loop' conversion will. It lowers CO by adding an O2 sensor which tells the ECU how to adjust the fuelling for minimum emissions. The details are in the Wiki here: https://wikilec.com/view/Converting_SE_ ... d_loop_ECU
I can provide the 9930 or 1499 chip for the closed loop conversion with standard boost profile or with the Kilimanjaro or Everest increased boost profiles.
Postby JimmyB » Thu 12.11.2026, 16:05
Thanks for your prompt reply.
Yes, it is a 1991 SE.
I'll check back with the MOT, but the car is extremely fumey (if that is a word) so I'm not surprised it failed. I'll certainly try the C02 pot adjustment as a start.
Going forward I want to move to a closed loop conversion so would be interested in buying one of your chips/boards. I'm not fussed about huge increases in power but I suppose a bit more boost would be fun. I think a Kilimanjaro is the one to go for.
James
JimmyB
Postby RonR » Sun 15.11.2026, 13:06
JimmyB wrote:the car is extremely fumey
If it's that bad you may have another problem:
If the exhaust has black soot in it, it could be a duff Temperature sensor in which case the ECU will see the engine temp at -39 Deg C and will dump more fuel into the engine to compensate. This can be checked with Elanscan if you have it.
Postby majic » Sun 22.11.2026, 21:58
Hi, I’m new to here but a Elan owner since March :-) I would like to get an Everest chip and see the great work you put in to these on the thread. Please can you pm me so we can get one on the way to me. I’ve got a 1992 SE model open loop. Happy to look at options.
Thank you, MJ.
majic
Postby Clicker72 » Tue 24.11.2026, 16:09
@Ron - I'd be interested in the mountain chip as well for a fed Elan as well. Let me know on availability. Thanks!
Clicker72
Postby JimmyB » Thu 26.11.2026, 11:27
Thanks Ron,
Unfortunately I don't have an old pc to run elanscan. According to what I've read on the forum it doesn't work on the latest OS. I can probably pick up an old PC somewhere and buy a cable if it is the recommended way forward.
Regarding the emissions, there is more of a very thin white smoke on start-up, rather than anything sooty, but it is still very fumey in the cabin when up to temperature. I thought it may be a cracked manifold, but I can't see or hear anything, and I'm not sure if that would impact CO2 readings. it probably makes sense to swap out the sensor anyway.
That said, I would like to move to a closed loop system as part of a general recommissioning, so can you put my name down for one of your chips :D
Once I've got the MOT I can move on to the real expense of the full respray it needs - ouch.
JimmyB
Postby RonR » Thu 26.11.2026, 12:01
James,
You don't need an old PC to run Elanscan, the version we updated in 2024 Here will run on the latest Windows OS using a USB cable based on an "FTDI" chip, as sold by GeoffSmith or sometimes Tuga2112. There's also a video by Toby Here on how to make your own.
P.S. You have a PM.
Return to Elan Products for Sale (New Products for Sale)
