by emlynt » Thu 14.07.2005, 20:50
Hi,
My Series 1 turbo .... it feels like a rev limiter is engaging at 4000 revs ... backfires etc....
Seems to be intermittent too?
Advice very very welcome
ta
E
emlynt
by M100 TWO » Thu 14.07.2005, 21:03
Hall effect sensor will cause engine check light to come on with a code 41 with a limit of 4000 rpm Lotus had them on special offer at about £25
M100 TWO
by emlynt » Thu 14.07.2005, 21:31
No light comes on? How do I check the code?
I guess for £25 I should change anyway
E
emlynt
by Candles » Thu 14.07.2005, 23:03
Does it do it after you've been at full power? Describe exactly when it happens and whether the orange 'check engine light' comes on. Also describe how long you are limited to 4000rpm. Sounds like it could be overboost.
Candles
Candles
by ESM » Fri 15.07.2005, 07:15
To read the code see
here
ESM
by Batman » Fri 15.07.2005, 17:26
Best to find out what the code reading is, your symptoms sound the same as what I had and that ended up being a coolant sensor.
Batman
- Tinkerer
by emlynt » Fri 15.07.2005, 18:21
mmmm The engine warning light doesnt come on - Ever - The bulb/or something is broken.
But .. I started it this evening, I revved the engine to above 4k all was well, then revved to 6k ish and the exhaust poped a bit - then the 4k limit was back.
It feels just a like a 4k rev limitter......
emlynt
by emlynt » Fri 15.07.2005, 18:57
double mmmmmm
left the car for 1/2 hour. Still wont go above 4000
emlynt
by ESM » Fri 15.07.2005, 20:48
Its not unknown for unscrupulous w@nkers to pull the bulb when selling a car that's setting a code... perhaps that happened here?
Anyway, either fix the bulb or get hold of an ALDL interface and run ElanScan to diagnose the issue.
ESM
