goodyears or yokahamas???
Postby clemo » Thu 08.07.2004, 18:27
getting a set tommorrow so which should i go for.??<br><br>anyone had experiances of the yokies?<br><br>my tyres need only be for dry weather so maybe go for somthing completely different??<br><br>many thanks for any advise given<br><br>clemo
clemo
Re: goodyears or yokahamas???
Postby Matt Welsh » Thu 08.07.2004, 19:58
Check www.tirerack.com --> not to buy from them but to enter in your tire size and ask for summer tires ONLY (you don't need all-season) & other parameters to help you narrow down your tire selection.
Matt Welsh
Postby stevo » Thu 08.07.2004, 22:39
ive just fitted a full set of yokohama a539's 205/40x17 at £80 a corner and my first impression is very good. theyare more forgiving that the proxes and grip better in the dry but iv'e not tryed them in the wet yet.
stevo
Postby Matt Welsh » Thu 08.07.2004, 23:51
BTW, if you call The Tire Rack and discuss with them what are looking for in a tire they will suggest the right tire for you.  Not bad for the price of a toll-free number!
Matt Welsh
Postby Jeff » Fri 09.07.2004, 04:14
I just bought a set of Goodyear Eagle Gsd3s about 2 months ago.  They are extremely grippy in the dry, and do pretty good in the wet.  I had Yoko Parada's before, and were somewhat dissapointed with them compared to the Goodyears; seemed to push much more in the wet,  though this might due to the relatively high tire pressure that I was using.  And they did not seem to be as grippy on dry pavement as the Goodyears are.
Jeff
Postby rob » Fri 09.07.2004, 06:20
Clemo, the F1's are the muts I have had them on for 18 months in all weathers BUT front now need replaceing after 6000 miles, so unless you have loads of money or donot do many miles forget he F1's.<br><br>Sy has had Toyo Proxy's on has done 10 billion miles the tread has hardly worn and they are as cheap as chips, these are the one's I will be going for.<br><br>Just my 2p worth  ;D
rob
Postby KevH » Fri 09.07.2004, 07:56
[quote author=stevo link=board=wheels;num=1089307636;start=0#2 date=07/08/04 at 14:39:17]ive just fitted a full set of yokohama a539's 205/40x17 at £80 a corner and my first impression is very good. theyare more forgiving that the proxes and grip better in the dry but iv'e not tryed them in the wet yet.[/quote]<br><br>I've got the same tyres, and they grip pretty good in the dry, I also have not tried them in the wet though.<br><br>Kev
Wot no Loti
KevH
Postby muley » Fri 09.07.2004, 09:09
I recently had Toyo Proxes fitted and I am very pleased with the ride and handling - a lot better than Goodyears IMHO. They've got a butch tread too, if that's your bag!
Postby Rambo » Thu 15.07.2004, 22:49
I'm a Goodyear Eagle F1 fan but have found them much better wearing than Rob.  5000 miles since October and not a bit of wear on the fronts.  Perhaps I don't corner as fast as they do in Halesowen ??
Postby Sy V » Fri 16.07.2004, 06:53
I think you'll find it's Rach doing rally-cross to and from work...You'll have to let her drive the Golf Rob!
LEC Godfather
Postby sams_elan » Fri 16.07.2004, 08:02
I had the toyo's fitted when i first bought the car and dont really rate them in the dry however in the wet they are fantastic. I have yoko 539's fitted now which are better in the dry but scary in the wet. <br><br>All depends on what you are looking for. Im in for good dry handling and driving like an old lady in the wet.
sams_elan
Postby ESM » Fri 16.07.2004, 08:10
I'm also pretty cautious in the wet but the Elan is reputedly the fastest Lotus of them all when its wet....
ESM
Postby Jon » Fri 16.07.2004, 10:31
<br>The Goodyear Eagle F1s are superb tyres - their sticky compound means they hold to the road in the dry, but they also have a funky anti-aquaplane tread which make them damn good in the wet too.<br><br>It is certainly true to say that after 6000 miles they are bald as a coot!!<br><br><br>You used to be able to get a harder compond higher mileage Eagle F1 (I used to have a set which did 16000 miles and still had more tread on them than a brand new set of the latest ones) - although they seem to have stopped making them.<br><br>That said, despite the obvious codt disadvantage, I still think the new F1s offer a far better (if shorter) drive.
Jon
Postby Paul.P » Fri 16.07.2004, 10:58
Clemo, have you thought of the Michelin Exalto`s. I know there quite expensive, but are supposed to wear really well, & handle really well, wet & dry.
Postby a5gcd » Wed 13.04.2005, 18:55
<br><br>[quote author=stevo link=board=wheels;num=1089307636;start=0#2 date=07/08/04 at 14:39:17]ive just fitted a full set of yokohama a539's 205/40x17 at £80 a corner and my first impression is very good. theyare more forgiving that the proxes and grip better in the dry but iv'e not tryed them in the wet yet.[/quote]<br><br>Stevo<br>Now you have had the A539's on over the winter, how have they performed in the wet. I'm looking at the Donington offer by the South West Lotus Centre for new 16 inch Feds and A539s at £500. Any performance info would be useful<br><br>Geoff
a5gcd
Postby clemo » Tue 19.07.2005, 09:34
just about to order up a set of 15" for the B.R.GRANDAD ..
so it either
bridgestone potenza s-03 pole postions.
michelin pilot sports
michillen exaltos.
some luck bugger will inherate a nice set of boots on this car when i move it on...(soon)
will post the clemo tyre test result ..
clemo
Postby Doug » Tue 19.07.2005, 21:02
haven't used any on yer list, Dave, but I'd vote for the SO-3s
Postby Fubar1764 » Wed 20.07.2005, 02:34
Had the Bridgestone RE730s. They were the baby brothers of the SO2s. Amazing grip. The only drawback was the dental work I had to get replaced from being shaken loose! ;)
Great tires, but you're not going to like the harshness. If the Elan's your daily, I'd try something with a softer sidewall than the SO3.
-Your "Jack" of all trades
Fubar1764
Postby nitroman » Thu 21.07.2005, 00:03
Recenty rotated the Khumho's (225/45-16) on the back with the Falken Azenis (215/45-16) which had been on the front. Lots of wheelspin now with the Khumho's up front which impresses the babes but you know it's all for show and naught for go... not just in a straight-line but when gunning the car between lanes too. All this is without using nitrous, a scary thought! Never realized how truly good the Falken Azenis were until they were no longer there!
Falken now has a new Azenis, the model 615 which have replaced the model 215 on my car. Looks like a simple upgrade to the tire but the hitch is that they are not offered in a 16" size which will fit the Elan; yikes! Looks like I'll next be going to the set of Dunlop SP9000 which I bought at closeout prices. They were the best tires Dunlop made at the time (2 years ago) and have been sitting in my inside storage room; size 225/40-16.
nitroman
Postby nitroman » Thu 21.07.2005, 05:45
I take back what I said about the new Falken Azenis model 615. Just been reading about them on the Falkentire homepage and they quote "Increased internal void ratio delivers enhanced wet grip and aquaplane resistance". Well that's great but I want a tire that is designed to perform well only in the dry. "Increased internal void ratio" means MORE void space, ie, more tread in the tire and LESS RUBBER ON THE ROAD! So poo-poo on your changes to my beloved tire, Falken.
I could still find a few places selling/listing the old model (Falken Azenis RT-215) but they wanted a premium for them; like $127 vs the $99 Discount Tire used to charge. Too bad, dem was da best tires I EVER had. :cry:
nitroman
Return to Wheels and Tyres
