by badger » Sun 26.03.2006, 23:47
Considering purchasing a normally aspirated M100 in excellent condition, would really prefer a turbocharged car.
Would it be possible to fit a turbo upgrade at later date. would the cost be prohibitive?
badger
by Enright » Mon 27.03.2006, 00:06
I think it would be a right ball-ache finding and fitting all the associated sensors, electrics and wiring, and you would probably end up spending more than if you had just bought a decent condition SE in the first place.
Neil
- Modificator
by Guest » Mon 27.03.2006, 01:54
Thanks for the advice.
Hadn't considered extra sensors , wiring etc.
May as well continue the search for a decent SE Turbo.
Guest
by Doug » Mon 27.03.2006, 08:15
Anonymous wrote:May as well continue the search for a decent SE Turbo.
YES.
- LEC Founder
by Nige » Mon 27.03.2006, 10:55
badger wrote:would the cost be prohibitive?
Yes, different compression ratio, different clutch, different final drive. You would need to swap the whole engine and gearbox and then wire in all the sensors etc. Keep looking for an SE, although I do like my NA and don't see it as a lesser car, just not as quick.
Back in Blighty
Nige
- LEC Administrator
by badger » Tue 28.03.2006, 00:07
Test drove an SE Turbo today, noticeably quicker than n/a car when pushed.
Could hear slight whistle from turbo. Is this normal?
Also loud "whooshing" noise from power steer pump on slow turning.
badger
by Enright » Tue 28.03.2006, 00:29
All competely normal.
Neil
- Modificator
Users browsing this forum: ludo and 3 guests
