Where to buy Clutch
Drivetrain problems
Where to buy Clutch
Postby leonfoxyy » Tue 21.03.2006, 22:01
hi, just dragged the elan out of from winter hibernation and decided to get enthusiasic and fit a new clutch, got quoted £250 plus vat for clutch assy. Is this the going rate for uk prices? Also i read someone was getting one posted from the usa...if so how much?
leonfoxyy
Postby Paul.P » Thu 30.03.2006, 06:55
Seems about the right price, i bought one last year.
Postby Dean » Mon 10.04.2006, 18:31
Got one at xmas about same price
Dean
Postby davel » Thu 13.04.2006, 08:37
I have the same problem, Quoted £243.27 for assembly inc vat
Would appreciate any suggestions on import, as I have plenty of time
davel
Postby davidjt » Thu 13.04.2006, 10:02
My Stage 2 Kevlar clutch came from Horsepowerfreaks in the US. (Not strictly necessary unless you are one.) 8)
davidjt
Postby jordizr1 » Thu 11.05.2006, 12:35
is it really imperative to replace all parts of the clutch in the Elan, or just the disc?
yes it's mine and no you can't drive it
jordizr1
Postby Ultimatt » Tue 23.05.2006, 14:52
Would be helpful for me to know the answer to come of these questions also. Mine is on the way out - just about limits of adjustment; and get slight slippage with low gear boost. And as I'm looking at Everest chips, I'm thinking i might need to make sure all parts are tip-top.
Anyone further advice on clutches? Which parts need replacing? Are there cost effective alternatives to the OEM one? And which source offers the best price?
Matt
Ultimatt
Postby Monty » Tue 23.05.2006, 17:29
Your better of replacing the full clutch kit, here`s list from SJ`s site:-
Clutch | Center plates
CLUTCH CENTRE PLATE (For SE Turbo) A100Q6003F EACH 97.46
Clutch | Pressure plates
CLUTCH PRESSURE PLATE (For SE Turbo) A100Q6011F EACH 71.90
Clutch | Release bearings
CLUTCH RELEASE BEARING (All models) A100Q6013S EACH 37.68
All + vat :shock:
http://www.sjsportscars.co.uk/partsandaccessories/srchRes.asp?Car_ID=9&Type1_ID=14&srch=&Submit=search
The other option is to go for a uprated clutch but this would have be bought from the USA
Postby Dico » Wed 24.05.2006, 08:09
And if anyones up for a group buy from the USA than put my name down for a spare :wink:
Postby ab2cv » Tue 06.06.2006, 22:28
How much would an uprated clutch from the USA cost? and how many people might we need for a group buy? I'm down for one given that I've been told my clutch is on its last legs (no slippage yet, but very high biting point)
Alan
ab2cv
Postby Ultimatt » Tue 06.06.2006, 23:45
I'd be up for an uprated clutch if it worked out at a comparitive price to the original replacement from Lotus (i.e. doesn't require me to re-mortgage) :wink:
Now correct me if I'm wrong, but I had presumed that the clutch would be biting 'low' if it was on it's way out and at the limits of adjustment. In other words, bites very quickly when foot pressure is taken off.
If I'm wrong and a well worn clutch normally bites, as Alan suggests, then mine might have just been adjusted the wrong way :?
Could someone clarify for me?
Matt
Ultimatt
Postby Ultimatt » Wed 07.06.2006, 06:28
Ok... I've just driven the car and realised it does bite 'high', not low as I thought yesterday. Being a bit of a plonker
So therefore I probably need the new clutch more than I made out. Mine is not slipping yet also, but the bite does make it a bit sharp to drive.
Matt
Ultimatt
