Blow job
Blow job
Postby Stef » Wed 26.07.2006, 17:35
Blipi is blowing on the 3 bolt part of the Zaust where it attaches to the manifold (I think) bit at the engine end of the system. There is a shield thingy there too which happens to be rattling slightly... Need a new gasket kit and bolts so I have been told.
Anyone know if this part has a name so I can order it without sounding like a numpty trying to describe what I need?
Is this the area the Stiffy attaches onto? Would the Stevo doode have bits for me to ifx this?
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Dave M » Wed 26.07.2006, 19:04
Sounds like it is the gasket between the head and the manifold? The piece that fits this, right?:
http://pg.photos.yahoo.com/ph/themeyers ... pg&.src=ph
If so, I would think "exhaust manifold gasket" should get you what you need.
As for the "stiffy" part of your blow job (what?! :smt018 ), that part connects to the turbo and continues on to the rest of the exhaust (O2 housing).
Dave M
Postby Stef » Wed 26.07.2006, 20:32
Could be that but there is only one connection not 4! Where the zaust attaches to a nasty cast irn lump of a thing coming down from the engine.
Will order the 'exhaust manifold gasket' and see!
Cheers!
Stef
Postby Dave M » Wed 26.07.2006, 20:46
Hold on, Stef...maybe it's something else. Is the leak on the engine side of the turbo or the tailpipe side of the turbo? Do you still have the pre-cat in your system? Maybe when you said "manifold" I was thinking further up the system. The picture I linked to above is the manifold that goes between the turbo and the head. It may be the connection to the pre-cat... In that case it may just be a standard 3-bolt, 2.25" (if that is the stock size - sorry, just going from memory) exhaust gasket. Should be able to get it at any muffler shop.
Dave M
Postby Dave M » Wed 26.07.2006, 20:58
OK, here's a pic of Matt's shiny precat-to-downpipe connection. Yours (and everyone else's!) will likely look a bit more rusty. Is this the problem area?
http://lotuselancentral.com/forum/download.php?id=2148
Dave M
Postby Candles » Wed 26.07.2006, 21:00
No it isn't the manifold gasket you need, that is for between the engine block and the bit before the turbo. Mine doesn't have a gasket at the base of the cast section, just a bit of exhaust cement and the pipe under the engine has a slight lip on the flange :D creating a good seal. Your you-know-what (see previous sentence) probably just needs removing, cementing and retightening.
The bolts are standard metric (M8 IIRC) and easily available anywhere (within reason).
Candles
Postby Stef » Thu 27.07.2006, 22:13
Yep, that is the area! And Blipi's is definatley not shiney and clean!
Stef
Postby Stef » Tue 08.08.2006, 17:51
Got the gasket and fitted. One task done!
Stef
Return to Exhaust
