Threads for help with computer maintenance, software and hardware advice, photos and photoshopping, and other topics related to keeping your computer healthy and online with us.
by Doug » Wed 20.12.2006, 07:58
here's the issue: my new laptop with XP will sometimes pop up a window which would normally include a button for me to press in the window--such as to allow or install something -- problem is this window is sometimes too small such that I can't read the whole message or see the button to press it!!
the window does not have sliders on it, so it is just too small for its purpose
question is: how to I remidy this, O computer gods ??
- LEC Founder
by Sy V » Wed 20.12.2006, 09:09
Is it a display size/settings thing, perhaps?
I'm definatley no computer god though...
- LEC Godfather
by ailwyn » Wed 20.12.2006, 10:57
I think it's just a feature.
I have the same problem with my anti-spyware software, everything else is fine, but when that pops up a message the text on the buttons are obscured by the message text.
As yet, I've found no solution (not that I've looked very hard).
Ailwyn
ailwyn
- Forum Member
by markv » Wed 20.12.2006, 11:44
I've had some of these problems intermittently before. You could try clicking somewhere on the window and then pressing the "End" key.
by Gary » Wed 20.12.2006, 17:46
Who let doug near a computer
by GeoffSmith » Fri 22.12.2006, 21:25
The facts:
1. Pop ups infrequent.
2. Pop ups not as big as they used to.
3. Can't see the pop ups.
The solution:
Viagra and a pair of glasses.
- Kitty Fiddler
by Doug » Sat 23.12.2006, 01:25
c'mon, I'm talking about a true problem I am trying to remedy on my computer
- LEC Founder
by Doug » Sat 23.12.2006, 01:29
so is there some setting somehow in Windows to change?
it gives me no option to resize the window or use sliders or scroll down the text or even highlight the text.
I am unable to push the buttons I need to push on a few things I need to do -- if I ran the computer in safe mode (for example) would it change this somehow and then allow me to see what I need to get to?
- LEC Founder
by GeoffSmith » Sat 23.12.2006, 01:39
Doug wrote:c'mon, I'm talking about a true problem I am trying to remedy on my computer
OK Mr. Grumpy. Wrong time of the month or something?
It's difficult to diagnose without seeing it, but the only thing I can think of is to use the magnifier: |Start|Programs|Accessories|Accessibility|Magnifier|. You should get a banner across the top of the screen which is a magnified image of where your mouse is pointing. Can you see anything of interest?
Geoff
- Kitty Fiddler
by Doug » Sat 23.12.2006, 07:28
interesting, but magnifier only shows me what I can alreadt readily see. It may be helpful for old eyes like yours, but I don't think it can help me see things I can't otherwise see . . .
- LEC Founder
by GeoffSmith » Sat 23.12.2006, 13:06
Doug wrote:interesting, but magnifier only shows me what I can alreadt readily see. It may be helpful for old eyes like yours, but I don't think it can help me see things I can't otherwise see . . .
I just wondered if there was something there which had been scaled down so small you couldn't see it.
If/when it happens again, grab a screen image (press the <Print Screen> button, then go into an imaging package e.g. Paint then <Paste> and <Save> the image) and let us have a look.
Geoff
- Kitty Fiddler
by paza1 » Sat 23.12.2006, 13:14
Have you used Windows Update? Maybe its a graphics driver issue.
Mark
Silver 1992 SE Turbo.
paza1
by Doug » Sat 23.12.2006, 17:12
here's a screen shot of a window that would have buttons to the right to allow me to install things . . .
sorry, don't have good program at home to shrink 8mb file well
- LEC Founder
by paulrwebster » Sat 23.12.2006, 20:26
If you press the Tab key it will cycle you through the buttons in the messagebox, even if you cannot see them. Press TAB and ENTER and you should be able to move on.
I suspect that your DPI setting is set to Large or Custom.
Right click on the Desktop and go to "Properties" on the menu which is shown. Go to "Settings" tab and then press the "Advanced" button. Change the DPI [Display] Setting to "Normal" or "Small" which is 96dpi.
499 Rubbish posts, Always a fanatic, never a God.
paulrwebster
by paulrwebster » Sat 23.12.2006, 20:31
Doug wrote:here's a screen shot of a window that would have buttons to the right to allow me to install things . . .
Oh, now I see the problem. Your screen is the wrong shape. It is far too wide
paulrwebster
by GeoffSmith » Sat 23.12.2006, 20:56
I presume you've got a widescreen laptop (flash bugger) and the pop-up box is assuming it is a more standard format (4:3).
If you change the aspect ratio of the display, you may be able to work around it, then put the diplay back to normal once you're finished:-
Right mouse on your desktop.
|Properties|Settings|Screen resolution|.
REMEMBER WHAT IT IS SET TO SO YOU CAN GO BACK TO IT!
Change the aspect ratio and see if you can see the options.
Good luck, let us know how you got on.
Geoff
- Kitty Fiddler
Return to Computer Help / IT Area
