running on 3 cylinders
Postby stevo » Mon 10.07.2006, 22:39
missy started pissing about the other day with an all new intermitant missfire then running on 3 cylinders. all the plugs are clean and reasonably new and i have robby robot chrome leads.
coil?
stevo
Postby GeoffSmith » Mon 10.07.2006, 23:58
Same happened to me. Try her tomorrow - it worked for me and it's never re-occurred.
Postby ESM » Tue 11.07.2006, 08:24
Unlike some posts :roll: :wink:
ESM
Postby ESM » Tue 11.07.2006, 08:29
To get back to the topic at hand - if a coil is the problem then you should run on two cylinders (1 & 4 or 2 & 3 from memory). If its just one cylinder then its probably not a coil. I'd try the remove one lead at time to identify which cylinders are firing and which not. Try not to electrocute yourself.
If you have the old leads about it would be worth trying them just to rule out a problem with the current set.
ESM
Postby WillB » Wed 12.07.2006, 12:53
Yep, I had a similar problem recently.
Changed the leads over and the problem was still there, replaced one of the coil packs and job done!
See my posting in the parts cross referance for the coil part number
WillB
Postby stevo » Wed 12.07.2006, 17:33
http://lotuselancentral.com/forum/viewt ... light=coil
nice one will, i'll try the leads first and if get no joy i'll change the coils :-D
stevo
Postby Paul.P » Wed 12.07.2006, 21:52
Surprised youve got time for this Stevo, between engine rebuilds ?
Postby stevo » Thu 13.07.2006, 00:55
news travels fast in small minds :wink:
stevo
Postby Paul.P » Thu 13.07.2006, 16:42
stevo wrote:news travels fast in small minds :wink:
Not if you read PH & can add up !
